A DIS re-election occurred on the specified level, causing restart to fail.
It is possible that a second failure occurred in the network during restart which caused the re-election to occur. It could also be that the configuration of a neighbor node changed the priority of interface, causing a DIS re-election.
Notice
%ifName%:L%level%: DIS change, restart failed
| Name | Type |
| ifName | String |
| level | uInt |
